New Tools! http://www-.luthiersforum.com/forum/viewtopic.php?f=10101&t=45477 |
Page 1 of 3 |
Author: | Clinchriver [ Fri Apr 03, 2015 9:47 am ] |
Post subject: | New Tools! |
Got a very well packed box from David & Hesh at Ann Arbor Guitars today ![]() |
Author: | Colin North [ Fri Apr 03, 2015 9:54 am ] |
Post subject: | Re: New Tools! |
TAS! Looks fantastic. Real quality. ![]() |
Author: | Hesh [ Fri Apr 03, 2015 9:55 am ] |
Author: | Clinchriver [ Fri Apr 03, 2015 9:58 am ] |
Hesh wrote: :D You are going to love it I am sure!!! Yep its pretty bad, I'm resisting the urge to take it apart.........sucessfully ![]() |
Author: | SteveSmith [ Fri Apr 03, 2015 10:01 am ] |
Awesome, I'm going to have to come see that one. |
Author: | Hesh [ Fri Apr 03, 2015 10:06 am ] |
Clinchriver wrote: Hesh wrote: :D You are going to love it I am sure!!! Yep its pretty bad, I'm resisting the urge to take it apart.........sucessfully ![]() Hey Buddy: As much as I can understand the temptation the assembly of these things takes hours because they have to be tuned as per a procedure so that all of the moving parts move effortlessly. As such I would not advise taking it apart.... ![]() ![]() Did you get a vac pump? |
Author: | Clinchriver [ Fri Apr 03, 2015 10:10 am ] |
Hesh wrote: Clinchriver wrote: Hesh wrote: :D You are going to love it I am sure!!! Yep its pretty bad, I'm resisting the urge to take it apart.........sucessfully ![]() Hey Buddy: As much as I can understand the temptation the assembly of these things takes hours because they have to be tuned as per a procedure so that all of the moving parts move effortlessly. As such I would not advise taking it apart.... ![]() ![]() Did you get a vac pump? Yessir & Yes. And Steve I'll bring it next Sunday |
Author: | jfmckenna [ Fri Apr 03, 2015 10:24 am ] |
Nice looking machine. What does it do? ![]() |
Author: | SteveSmith [ Fri Apr 03, 2015 10:30 am ] |
Greg, sounds good. I'll bring mandolin parts for inspection |
Author: | Clinchriver [ Fri Apr 03, 2015 10:51 am ] |
jfmckenna wrote: Nice looking machine. What does it do? ![]() Its the David Collins Saddle Mill |
Author: | WudWerkr [ Fri Apr 03, 2015 11:31 am ] |
How about bringing it up to St. Louis on the 18th and joining us at the Gateway Luthiers Show . I Might even have a Guitar it could be used on ! ![]() ![]() |
Author: | klooker [ Fri Apr 03, 2015 1:36 pm ] |
jfmckenna wrote: Nice looking machine. What does it do? ![]() Here viewtopic.php?f=10101&t=43204&hilit=sADDLE+MILL Kevin Looker |
Author: | Jimmyjames [ Fri Apr 03, 2015 2:03 pm ] |
In my mind I hear the theme song to _Star Wars_ . "That's no tool, it's a space station." -Ben Kenobi |
Author: | James Orr [ Fri Apr 03, 2015 2:17 pm ] |
Easily the sexiest luthier tool I've ever seen. Easily. And there are some hot ones out there! Sent from my iPhone using Tapatalk |
Author: | JSDenvir [ Fri Apr 03, 2015 3:06 pm ] |
I think I just had a personal moment ![]() Steve |
Author: | David Collins [ Fri Apr 03, 2015 4:50 pm ] |
Just wait until you get a chance to use it - not much of a learning curve (intuitive ease of use was a primary goal of its design), and I'm sure you'll love it even more the more you use it. As Hesh said, disassembly is not recommended. There's no hidden secrets which can't be appraised from the surface, and reassembly is not a simple process. Even with all the parts precision CNC'd, putting it together demands a very particular order of operations of aligning and torquing each part and screw just right, to ensure that when other parts meet three steps later they do so correctly. The bearings and rails are so tight of tolerance that if the rails are torqued to the base unevenly it won't run as smooth unless assembled and calibrated with great care. As said though, there shouldn't be any real need to break it down, and my initial prototype has been used and abused for over ten years without loosing any of its precision or needing realignment, so it should keep going and going and going. The precision collets were an addition to this version, and really proved to be the one missing link I didn't have before. There was always that 2-3 thou runout I couldn't shake, but once I added these to the mix I can finally get that last step toward of perfection that eluded me for so long. |
Author: | Clinchriver [ Fri Apr 03, 2015 5:25 pm ] |
David Collins wrote: Just wait until you get a chance to use it - not much of a learning curve (intuitive ease of use was a primary goal of its design), and I'm sure you'll love it even more the more you use it. As Hesh said, disassembly is not recommended. There's no hidden secrets which can't be appraised from the surface, and reassembly is not a simple process. Even with all the parts precision CNC'd, putting it together demands a very particular order of operations of aligning and torquing each part and screw just right, to ensure that when other parts meet three steps later they do so correctly. The bearings and rails are so tight of tolerance that if the rails are torqued to the base unevenly it won't run as smooth unless assembled and calibrated with great care. As said though, there shouldn't be any real need to break it down, and my initial prototype has been used and abused for over ten years without loosing any of its precision or needing realignment, so it should keep going and going and going. The precision collets were an addition to this version, and really proved to be the one missing link I didn't have before. There was always that 2-3 thou runout I couldn't shake, but once I added these to the mix I can finally get that last step toward of perfection that eluded me for so long. Thats just how I'm wired I love to see what makes stuff work, ![]() |
Author: | JSDenvir [ Fri Apr 03, 2015 7:20 pm ] |
Okay, so someone has to ask. How much and are Dave and Hesh actually selling these things? |
Author: | Hesh [ Fri Apr 03, 2015 7:34 pm ] |
Steve I'll send you a PM with pricing and delivery. The Collins Saddle Mill was not designed for hobbyists or folks who cannot justify having this capability and currently our pricing barely covers the costs of manufacturing the mills. We are producing them in small batches for folks with commercial applications. Don't want to sound evasive so I am happy to provide a quote to anyone who asks but my preference is to provide pricing, terms, delivery via PM or email. Our pricing is subject to change so I don't want a permanent record of an incorrect price living forever on a forum. We are also not sponsors and with as many times as I have referred folks for the past 10 years to Lance when they troll the OLF looking for a quick buck without dropping the dime to be a sponsor that is the last thing that I would ever want to do to Lance either. Frankly too we don't see a market with OLFers again because the mill is not unlike a mini PLEK machine in so much as one has to have the volume and commercial applications to justify owning their very own Collins Saddle Mill. Thanks in advance for the understanding my friend. PM sent. |
Author: | guitarjtb [ Sat Apr 04, 2015 6:11 am ] |
Hesh wrote: Frankly too we don't see a market with OLFers again because the mill is not unlike a mini PLEK machine in so much as one has to have the volume and commercial applications to justify owning their very own Collins Saddle Mill. Hesh, Hesh, Hesh. Since when did hobby guitar builders need to "justify" owning a state of the art piece of equipment? ![]() ![]() ![]() Seriously, that is a fine looking machine. I certainly don't have the volume, unless you can find a way for it to sand pick guards. ![]() |
Author: | Tai Fu [ Sat Apr 04, 2015 12:03 pm ] |
I thought from the picture that this is a machine that shoots lasers and the laser cuts a precise slot into the part... But I think saddle milling need not be complicated, for years I've milled saddle slots by sticking the bridge to a table and routing it with an edge guide. Stewmac's saddle mill looks very promising especially when paired with Dremel routing base. It's just so expensive... |
Author: | johnparchem [ Sat Apr 04, 2015 12:21 pm ] |
Wow that is a fine looking tool. I like the laser guide and the precision it has. A little more high tech than my combined classical bridge, saddle slot and nut compensation jig. ![]() ![]() ![]() ![]() |
Author: | Clinchriver [ Sat Apr 04, 2015 12:41 pm ] |
Tai Fu wrote: I thought from the picture that this is a machine that shoots lasers and the laser cuts a precise slot into the part... But I think saddle milling need not be complicated, for years I've milled saddle slots by sticking the bridge to a table and routing it with an edge guide. Stewmac's saddle mill looks very promising especially when paired with Dremel routing base. It's just so expensive... Whats complicated about precisely measuring your saddle slot, lining up your router/base with a nice laser (turning on your vacuum pump) and cutting a very accurate slot regarding width, depth and angle? ( plus any degree of tilt you so choose) What a truly great tool does is make the task very simple ![]() If StewMacs price scared you off forget about this one ![]() |
Author: | Clinchriver [ Sat Apr 04, 2015 12:45 pm ] |
WudWerkr wrote: How about bringing it up to St. Louis on the 18th and joining us at the Gateway Luthiers Show . I Might even have a Guitar it could be used on ! ![]() ![]() Wud I'd love too, but getting to run through Hibdons.......I just bought two of their curly Honduran mahogany neck blanks ![]() |
Author: | Clinchriver [ Sat Apr 04, 2015 12:49 pm ] |
johnparchem wrote: Wow that is a fine looking tool. I like the laser guide and the precision it has. A little more high tech than my combined classical bridge, saddle slot and nut compensation jig. ![]() Nice, I like that jig also, Bishop? I just gave up on Dremel's for any kind of precision routing. Mine is a ball bearing model but you have so much slop in the housing its pointless. I wrapped the bearings in plumbers teflon tape for a crush fit and that helped but its still crappy. This is a total no brainer for me, cry once and laugh for a long long time |
Page 1 of 3 | All times are UTC - 5 hours |
